1993 Dodge Stealth No Compression
1993 DODGE STEALTH
121,000 MILES • 6 CYL • FWD • MANUAL
GOLANTH
car has spark when cranking no compression what could be the cause everything is turning smoothly
plugs are dry no fuel to plugs any help would be appreciated
Jan 26, 2009 at 10:45 AM
DOCFIXIT
  • 18,828 POSTS
You think timing belt maybe broken?
Jan 26, 2009 at 1:06 PM
GOLANTH
[quote:6cd3d6b2f1="Docfixit"]You think timing belt maybe broken?[/quote:6cd3d6b2f1] timing belt is on
Jan 26, 2009 at 1:43 PM
DOCFIXIT
  • 18,828 POSTS
Pull dist cap crank does rotor turn? Do you have acompression gague? if yes run cylinders.
Is there fuel pressure? spary carb cleaner into air intake does it fire?
Jan 26, 2009 at 2:04 PM
