1993 Dodge Stealth
1993 DODGE STEALTH
145,000 MILES • 6 CYL • FWD • MANUAL
BTAYLOR36
My stealth is having problems moving. It will start and go into gear fine but when i go to give it gas it just revs up really high and wont go faster than 15-20 mph. Its happened before and the first time a bad smell was coming out along with white smoke so i bled the clutch lines and refilled the clutch fluid but its still happening.
Oct 4, 2009 at 8:23 AM
CH112063
  • 1,320 POSTS
When was the clutch replaced? What mileage? How long ago? It's time for replacement of the clutch disk, pressure plate(clutch cover) and clutch release fork bearing. It will require much more expensive repairs if used in this condition. Joe
Use only Mitsubishi parts, or be prepared for a possible failure. ok
Oct 10, 2009 at 10:43 PM
