1992 Dodge Stealth WONT IDLE AND SPUTTER AT HIGH RPM
1992 DODGE STEALTH
TEXASBIGBEAR
Engine Mechanical problem
1992 Dodge Stealth 6 cyl Two Wheel Drive 168000 miles
THE CAR HAS BEEN SITTING UP FOR 3 YEARS IT STARTS RIGHT OFF THE BAT. IT WONT IDLE AND IT HESITATE AT HIGH RPM
Sep 3, 2008 at 10:56 PM
Check the fuel pressure this will tell you something about the fuel filter/fuel strainer in the fuel tank/fuel pump. If okay-check the idle speed control valve/motor and the EGR valve, throttle position sensor.
Sep 4, 2008 at 1:57 AM
