1992 Dodge Stealth when starting the engine missfires
1992 DODGE STEALTH
156,000 MILES • 6 CYL • FWD • MANUAL
JOHNS2
when starting the engine missfires then after a while it stops after a short peroid of time with the engine off when its started again it misfires
Oct 25, 2009 at 5:59 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Oct 25, 2009 at 6:16 PM
