1992 Dodge Stealth oil sensor
1992 DODGE STEALTH
BOXER64
Electrical problem
1992 Dodge Stealth 6 cyl Front Wheel Drive Manual
is there a wire that plugs into my oil sensor in my 1992 dodge stealth base model
Apr 10, 2010 at 4:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you mean the oil pressure switch? if you have the actual oil pressure gauge in the instrument cluster then no there is no wire, if you have just the oil pressure warning light in the instrument cluster then yes there will be one wire that controls the light. .
Apr 24, 2010 at 10:08 PM
