1991 Dodge Stealth please help!
1991 DODGE STEALTH
NJONES0827
Engine Performance problem
1991 Dodge Stealth 6 cyl All Wheel Drive Manual
Cursin in light throttle has a hesition and miss but WOT ok, worse when cold. Computer was scaned checks ok. Changed Air Flow Meter no change. Is trying to flood? because had to change plugs.
Jul 15, 2009 at 2:06 PM
Possible causes:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 15, 2009 at 2:34 PM
