hi im a shop owner for over a year -i have over 13 years in the field and i got a customer car , a 1991 dodge stealth 3.0 dohc -stick-non turbo-alrite this is whats up , the car runs good no codes - i did a tune up ,new plugs wires cleaned the throttle body,and a coil -it was arking,
it has a problem when on the highway in fifth gear when you put a load on the motor it feels like the throttle has a dead spot -it will clime in rpms a little the when it hits 2500 rpms it will jump and feel like it wants to take off-it felt like a bad tps sensor -so i tested the voltages and everything is ,i even tried a new sensor -no luck- i thought it could be a mas air sensor - same thing -i tested the wiring and even tried the sensor -nope ---so i need help !!!!!!! were would you go next ??
May 7, 2010 at 6:27 PM
