1991 Dodge Stealth Check Engine light diagnostics
1991 DODGE STEALTH
120,000 MILES • 6 CYL • 2WD • MANUAL
KPORTUE
I have an ODB2 tester but cannot locate where to plug it in. I feel like an idiot. Is there a ODB2 connection port or do I have to use a voltmeter.
Jan 15, 2009 at 6:45 PM
BUDDYCRAIGG
  • 2,262 POSTS
90% of the time it's under the drivers side dash
Jan 15, 2009 at 6:51 PM
MITSUMA06
  • 7 POSTS
it probably dosnt have an obdII port. obdII was not required by the govt untill 96. if it dosnt have one you can generate the codes through blinks of the check engine light by turning the key from off to on to off three times leaving it in the on position on the third cycle. the check engine light will blink and then pause and then blink untill it spits out all the codes. the codes are all two digits. so for example it will blink 3 times pause for a second and then blink 6 times. the code would be 36. im not sure in the refrence of the numbers tho. you would be best to contact the dealer for a list of which numbers mean what.
Jun 21, 2009 at 9:32 PM
BUDDYCRAIGG
  • 2,262 POSTS
do what mitsuma06 said
you probably have the old system, and don't even need a scan tool.
Jun 22, 2009 at 12:59 AM
