both lights on, won't blink on either side. hazard stay on without flashing. if module is the problem, where is it located. thanks, john
Feb 19, 2009 at 9:25 PM
CERTIFIED EXPERT
Check the turn signal control module under driver's seat
Feb 19, 2009 at 9:36 PM
DENNISGWAGNER
MEMBER
check the gray relay on the bottom of the fuse panel under the steering wheel. they it is bad and it goes bad because of the fuse panel itself. the new fuse panel comes with fuses and relays you should be able to pull it out and put the relay back in but it will happen again in a few days
Aug 1, 2010 at 8:32 AM
FABRIGOL
MEMBER
Did any of you guys figure out what the problem was?
May 10, 2019 at 10:46 AM
CERTIFIED EXPERT
Here is the blinker wiring diagrams so you can see how the system works and the instructions so you can replace the brake control module.
