1991 Dodge Spirit no spark at plugs no fuel from fuel pump
1991 DODGE SPIRIT
10,300 MILES • 4 CYL • 2WD • AUTOMATIC
BILLYBRAD
car will not start. i have replaced the coil, distributor , ecm, fuel pump relay and check fuel pump which tested ok. no spark from coil, plugs, no voltage going to fuel pump
Jun 17, 2009 at 4:15 PM
If you are getting no spark or fuel, it sounds like there is a problem in the auto shut down (ASD) circuit. If it doesn't receive a signal from the crank sensor, it will shut everything down. Question, have you checked if there are any codes stored in the computer?
Oct 17, 2009 at 12:30 AM
