1991 Dodge Spirit hesitation
1991 DODGE SPIRIT
109,400 MILES • 4 CYL • FWD • AUTOMATIC
COOLDANROCK
When I drive or try to excellerate, my car hesitates and then it picks up speed a few minutes after.What could the problem be. I put a new map sensor on,tuneup,gas filter,oil and filter change and air filter. The car is still doing the same thing.
Mar 14, 2008 at 6:34 PM
For a start check the fuel pressure if its on specs -test the throttle position sensor. Might also want to check the ignition timing and for restriction in the exhaust system to rule out the Cat.
Mar 14, 2008 at 6:59 PM
