First, disconnect the battery.
To access the fuel pump, you need to remove the fuel tank. Disconnect the battery and there are two steel straps around the tank that need removed. ALso, unscrew the filler tube from the body so the tank can drop out for you.
Try to do this on as empty of a tank of fuel as possible because it can be heavy. I recommend using a floor jack with something to protect the tank from damage to lower it.
Once the tank is out, at the top of the tank is where the fuel lines will be coming from. Basically it screws out and then you pull the pump out and replace it with the new one.
Here is a picture of the pump so you know what to expect.
Oct 17, 2009 at 12:13 AM
