My 1990 dodge spirit will not start. The problem began on start up when the engine started briefly, then died after about 10 seconds. Subsequent attempts at starting failed. At first I thought it was a starter problem due to the tach not indicating any engine RPM during cranking like it did prior. After replacing the starter I found this was not the case, and the engine turns over but no power gets to the plugs. Engine does receive fuel. When I checked the power leads to the ignition coil my voltmeter indicated 11.4 volts. I have replaced the Hall effect module, but still nothing. Any help you can give me would be greatly appreciated.
Mar 12, 2009 at 10:45 PM
