[quote:c66a0d429f="Mikeybdman"][quote:c66a0d429f="shadow92"]ok, I have a Dodge Shadow 92, problem is my blinkers wont work, i changed my flashers... and i messed around with it for 2 weeks now...i cant find the fuse box or any wires...i also checked my hazard lights to see if they worked, and the didnt...any ideas? im open to any thing :!:[/quote:c66a0d429f]
Looks like the turn signal flasher is on the drivers side in the center of the A/C duct. Located on the left instrument panel support. If this is one you have changed, then never mind. There is a fuse, listed as fuse #15 10amp. It may also go thur the Hazard Warning Flasher which is a round flasher locared on the relay module.[/quote:c66a0d429f]
I have a 93 Convertible. Is the location the same as the 92 mentioned above? My 15 yr son just bought this car and I have to figure out how to make the blinkers work, as well as the brake lights. Any info would be appreciated. :)
Sep 1, 2007 at 6:41 AM
