94 dodge shadow
1994 DODGE SHADOW
JASONW117
I'm trying to change a fuel filter on a 94 shadow, do I need a special tool to remove the fuel lines from the filter? I cant seem to figure it out, so any help would be greatly appreciated.
Mar 21, 2006 at 5:38 AM
JPAM
  • 307 POSTS
i got a 94 spirit.. and its easier than looks.. the lines that go onto filter are quick disconects... there well be a plastic piece that well be between filter and metal end of gas line..plastic piece is already inserted into metal end... push plastic piece into metal end and hold it and pull filter away from gas line... your new filter should come with a piece of gas line with a quick discontect on it, you can practice with that..
hope that helps you.. good luck jess s.
Mar 22, 2006 at 1:40 AM
ICURIOUS1
[quote:647adcff91="jasonw117"]I'm trying to change a fuel filter on a 94 shadow, do I need a special tool to remove the fuel lines from the filter? I cant seem to figure it out, so any help would be greatly appreciated.[/quote:647adcff91]
I changed mine the other day. THe one side has a regular hoe clamp. but the other side yo should use a special tool to depress the lock. I could not get the tool in so I used a screw driver to depress the lock and pull the hose off the filter..
Good luck:
Lar
Sep 8, 2006 at 9:56 PM
