1994 Dodge Shadow soft peddal
1994 DODGE SHADOW
ROUELLET
Brakes problem
1994 Dodge Shadow 4 cyl Two Wheel Drive Automatic
All components of the system have been changed.
wheel bearing are good, Car had been parked for 3 months, when it was returned to sevice it had a soft peddal. I have adjusted the pushrod from booster to master with no change. Is there a special bleed sequence for this model?
Jul 23, 2008 at 10:33 AM
Hi:
Nothing special for bleeding the brakes. However, like all cars, you should start at the wheel which is furthest from the master cylender and work your way back to the closest which will be the left front.
Make sure the master cylender is full, the rear brakes are properly adjusted, and there are no leaks. Also, check the rubber lines for bulging when the brakes are applied.
Let me know what you find.
Oct 19, 2008 at 12:02 AM
