1994 Dodge Shadow poor accelleration, sparks at distributor
1994 DODGE SHADOW
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROTTING_DODGE_SHADOW
I have a 1994 dodge shadow. It appears to have some sort of electrical problem. When it first started, the car would go about 8 city blocks without a problem. Threaten to stall, loose all acceleration and jerk around for about another 8 blocks and then improve a great deal. Now the problem more spread out (rarely threatens to stall, but big loss of accelleration).
I have noticed when it does this (misses") there is a spark just under the distributor cap. Where exactly is hard to tell. When I look at it in the light, there does not seem to be a place for it to spark It is hard to tell in the dark. Someone told me to replace the spark plugs (they said the distributor cap looked fine)
Is this the right approach ?
Now they are saying I should replace the spark plugs.
Sep 22, 2008 at 10:09 PM
Hi:
It sounds as if you may need a new distributor cap, rotor, and wires. Based on what you're saying, it sounds like a plug wire is arching to the nearest ground. Look on the plug wires near the dist. Check for small gray spots on them where they may be arching.
Let me know what you find. Also, keep in mind, the ignition produces a lot of power, so the arch could jump up to three inches.
Oct 18, 2008 at 11:05 PM
