1994 Dodge Shadow lower radiator hose housing at rear of bl
1994 DODGE SHADOW
124,000 MILES • 6 CYL • FWD • AUTOMATIC
JEFFB33
hi guys first let me thank you for this site, i have a 94 shadow w/ a 3.0 at the back of the block is a housing that the lower rad. hose connects to and this housing bolts to the block it is leaking at the bottom of this housing i know there is a o-ring seak in there which a friend replaced and it still leaks when the engine is running, he didnt use a factory 0-ring is the anything else in there that could be leaking? he didnt know if this intake was a wet intake or not, it seems to be leaking at the base of this housing on the bottom side,is there anything inside that could cause this to leak besdies the 0-ring? any insight would be very helpful, thanks
Jul 24, 2008 at 5:04 PM
Hi:
If there is still a leak, I would suggest getting an new seal from a chrysler dealer. There really isn't anything in there that would cause the problem. Also, when you remove the housing, make sure to check for cracks. If I recall, they are made from pot aluminum which can crack easily or warp. Let me know what you find.
Oct 18, 2008 at 11:56 PM
