I have a problem with the front brakes overheating and releasing very slowly from a stop. I have changed pads, rotors and calipers with the same results (no brake pull however). The caliper pistons will not compress into the caliper unless the brake line is cracked slightly open at the banjo bolt. could this be a master cylinder or a proportioning valve problem? It seems to be worse in hot weather.
Jul 19, 2008 at 2:53 PM
