1993 Dodge Shadow No brakes
1993 DODGE SHADOW
MAYKAY123
Brakes problem
1993 Dodge Shadow 4 cyl Front Wheel Drive Automatic
The hose on the brake booster was knocked off. Now there is a hissing sonund in the brake pedal area when the brakes are mashed. It stops after they are mashed a couple of times. I have no brakes. Besides bleeding the brakes, should this make a difference or what can I do? I will donate if I am saticified
Nov 27, 2008 at 6:54 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The hissing sound will be a vacuum leak at the booster, check the hose fitting into the booster this is usually plastic and it may have cracked, check this first.
mark (mhpautos)
Nov 27, 2008 at 10:23 PM
