i have a 1992 dodge shadow 2.5l , replaced dist. cap,rotor,plugs and wires ignition module,coil,pcv valve,fuel filter,coil,air filter, vacuum lines checked timing compression(130 all cylinders) am getting miss at idle and around 2000 rpm under load, really bad when cold gets better whem warmed up no check engine light and have ran injector cleaner thru two tanks so far
Jun 28, 2009 at 10:20 PM
