1991 Dodge Shadow NO FIRE
1991 DODGE SHADOW
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHICKENLADY83
  • 4 POSTS
I HAVE NO FIRE TO THE COIL WHEN TRYING TO START-I HAVE CHANGED THE CAP AND ROTOR-I HAVE CHANGED THE PKUP COIL AND DISTRIBUTOR AND HAVE REPLACED THE AUTOMATIC SHUT OFF RELAY SWITCH BUT STILL CANNOT GET THE CAR TO START. THE CAR WAS RUNNING FINE AND THEN IT DIED THEN THE NEXT DAY IT STARTED FOR A FEW MINUTES THEN DIED AGAIN AND NOW I CANT GET IT TO START AT ALL.
Aug 17, 2009 at 6:50 PM
WINEBURGER
  • 82 POSTS
you say thers no power to the coil while cranking?
Aug 17, 2009 at 7:27 PM
CHICKENLADY83
  • 4 POSTS
no power at all to the coil while cranking-
what do you think it is?
Aug 17, 2009 at 8:42 PM
WINEBURGER
  • 82 POSTS
check your fuses and fuse links
Aug 18, 2009 at 7:55 AM
CHICKENLADY83
  • 4 POSTS
yup checked all that too
Aug 18, 2009 at 8:50 PM
WINEBURGER
  • 82 POSTS
see if you have power to coil; injector with key on
Aug 19, 2009 at 7:25 AM
CHICKENLADY83
  • 4 POSTS
I do not have power to the coil. It does not have injectors it has throttle body.
Aug 19, 2009 at 4:33 PM
WINEBURGER
  • 82 POSTS
the injector is in the top of the throttle body.
Aug 21, 2009 at 7:51 AM
