1991 Dodge Shadow car will not start
1991 DODGE SHADOW
116,000 MILES • 4 CYL • FWD • AUTOMATIC
91DODGESHADOW
  • 6 POSTS
good evening my car will start in the morning , but as soon as i shut it off it will not start untill i wait 6 to 8 hours it will crank and try t start but will not start untill i wait not even haveng someone jump me will not work
and then i when i touch wies under the car near the fuel pump some times it will start
but i have also changed the fuel filter and then it started right a way and then it stoped working after using it once please help we are tring to get it fixed and do not have to much money
Mar 27, 2008 at 7:00 PM
BMRFIXIT
  • 19,053 POSTS
u need to check them wires at the pump
check the coil also
Mar 27, 2008 at 7:12 PM
BMRFIXIT
  • 19,053 POSTS
to answer your PM
When it does not start you need to check for spark
pull one of the spark plug wires place it near ground
ask a helper to crank the engine
you watch for a spark arching from the wire
also check the relays at the side of the fender
and let me know
Mar 27, 2008 at 7:22 PM
BMRFIXIT
  • 19,053 POSTS
From: 91dodgeshadow To: BMRFIXIT Posted: Thu Mar 27, 2008 7:27 pm Subject: hello oh ok it has new spark plugs and wires and it also has a new timing chain does that mean anything
all good but you need to check for spark arching
and let me know
Mar 27, 2008 at 7:33 PM
91DODGESHADOW
  • 6 POSTS
[quote:8351946c90="BMRFIXIT"]From: 91dodgeshadow To: BMRFIXIT Posted: Thu Mar 27, 2008 7:27 pm Subject: hello oh ok it has new spark plugs and wires and it also has a new timing chain does that mean anything
and let me know[/quote:8351946c90]
so if it does spark what does that mean and if it does not what does that mean
Mar 27, 2008 at 8:13 PM
BMRFIXIT
  • 19,053 POSTS
if it does you need to look for fuel and fuel pump
and if it does nt you have coil relays
replace crank sensor
Mar 27, 2008 at 8:17 PM
91DODGESHADOW
  • 6 POSTS
[quote:1e7c23fbdc="BMRFIXIT"]if it does you need to look for fuel and fuel pump
replace crank sensor[/quote:1e7c23fbdc]
it is the pick up coil or the ingition coil
Mar 27, 2008 at 8:44 PM
BMRFIXIT
  • 19,053 POSTS
do you have spark or not
Mar 27, 2008 at 8:51 PM
91DODGESHADOW
  • 6 POSTS
[quote:135fb4f725="BMRFIXIT"]do you have spark or not[/quote:135fb4f725]
yes there is a spark
sorry i looked at it and i was looking on line at some things too but yes it does spark too
Mar 27, 2008 at 8:53 PM
BMRFIXIT
  • 19,053 POSTS
then u should be looking for a fuel issue
turn key on and listen at the rear by the tank for the fuel pump does it come on when 1st key on
Mar 27, 2008 at 8:58 PM
91DODGESHADOW
  • 6 POSTS
[quote:735eb07f87="BMRFIXIT"]then u should be looking for a fuel issue
turn key on and listen at the rear by the tank for the fuel pump does it come on when 1st key on[/quote:735eb07f87]
it some times does and then some times i do not hear it but the car does tun on
Mar 27, 2008 at 9:01 PM
BMRFIXIT
  • 19,053 POSTS
When its doesn’t work you need to check for power (with key on or and when cranking)
at the pump and if you have power then the pump is no good
and is no power then check and replace the relay
check wiring
Mar 27, 2008 at 9:20 PM
91DODGESHADOW
  • 6 POSTS
[quote:3200281342="BMRFIXIT"]When its doesn’t work you need to check for power (with key on or and when cranking)
check wiring[/quote:3200281342]
thank you for being so understanding
one more thing i just replced the fuel pump last year and how bad is wireing to replace
Mar 27, 2008 at 9:25 PM
BMRFIXIT
  • 19,053 POSTS
check the connector and as for wiring u need to look for a weak wire and also you may want to try a new fuel pump relay
one year old pump it still could be bad just check it when the car not starting for you
Mar 27, 2008 at 9:32 PM
