1989 Dodge Shadow rear bearings
1989 DODGE SHADOW
EAQNNEJAYK
Drive Train Axles Bearings problem
1989 Dodge Shadow 4 cyl Front Wheel Drive Manual
how do you remove the bearings
Aug 3, 2009 at 8:30 PM
CH112063
  • 1,320 POSTS
The bearings are in the rear drums. You take the drums off and use a punch and bearing race driver with a hammer to remove and replace the races that come with the new bearings. It is not very difficult but its better to have those three tools and a water pump pliers to set the preload as your final adjustment. Use new cotter pins and clean and repack the bearings and drums using wheel bearing grease. Make sure the rear spindles are ok and "down the road". Ok eaqnnejayk. Good luck.
Sep 1, 2009 at 7:01 PM
