Vehicle did this two years ago, replaced pickup coil and that corrected the prob. So I replaced the p/u coil again, started it, ran it for 30 minutes. Turned off to button everything up, restarted and it ran for 30 seconds then cut off. Replaced Coil, start/run relay and ECC as this is has TBI was told it doesn't have an Ign module, or if it did it was in the ECC. After I replaced the ECC the truck started, I let it run for an hour, drove it down the road about 4 blocks, it shut off again and would restart, but only run for about 10 seconds. Thanks for any suggestions
Jan 13, 2010 at 6:33 AM
