1989 Dodge Ramcharger Engine Freeze Plugs
1989 DODGE RAMCHARGER
73,199 MILES • V8 • 2WD • AUTOMATIC
REX DUANE
My freeze plug on passenger side rear blew out. How do I get to it and what type of freeze plugs would be best for it /
Dec 7, 2008 at 1:10 PM
Hi:
The only way is from the underside of the vehicle. You can replace it with a standard steel plug or they do make a rubber one that expands into the opening when you tighten a bolt on it. If you have no access for a hammar to tap it in, I recommend using the rubber one.
Let me know if this helps.
Mar 12, 2009 at 6:01 PM
