1987 Dodge Ramcharger rotor
1987 DODGE RAMCHARGER
SEESUZ
Brakes problem
1987 Dodge Ramcharger V8 Four Wheel Drive 96000 miles
cannot remove rotor. need good instructions. will not come off axle
Feb 15, 2009 at 10:51 AM
MIKE H R
  • 3,094 POSTS
a lot of rotor get rusty and tend to be a pain getting off. soak the roator hub with wd 40. Then tap the center with a hammer, you will have to wiggle it loose. once it starts to move then keep working it until you can get it off, before you replace it clean the hub with a wire brush.
Feb 15, 2009 at 11:17 AM
