1986 Dodge Ramcharger rotor
1986 DODGE RAMCHARGER
17,900 MILES • V8 • 4WD • AUTOMATIC
BSPENCER332006
I cannot get the rotor off how do you get the rotor off thankx
Jan 23, 2009 at 11:10 AM
SCERMAK
  • 4 POSTS
take the rotor off the truck, lay it on the ground with the lug nuts facing up, take a big hammer and knock the lugs out. mine seperated when i did this but if your hub is frozen to the rotor you might need to put it in a press. the lug nuts are holding the rotor on. you can install it the same way but i tried it with a punch and hammer and there was still slack inbetween the hub and rotor, had to use the press. good luck hope it works out for you.
Jan 27, 2009 at 10:46 PM
