1985 Dodge Ramcharger Vibration and High pitch noise
1985 DODGE RAMCHARGER
104,227 MILES • V8 • 2WD • AUTOMATIC
RANDY STARBUCK
I just bought a 1985 Dodge Ramcharger. I've been able to trouble all previous problems and fix them myself untill now. Here's the problem, when I am driving and my speed reaches 40 mph my speedometer cable goes crazy and a high pitch sound and vibration comes from the dash. I thought at first it could be the u-joints. So I replaced them. I'm still having the problem. My transmission shows no sighn of needing repair. The truck doesn't shake or wobble and the motor mounts look to be in good shape. I've asked around but nobody seems to have an answer. I'm hopping that maybe someone will be able to help with my problem. Thank you,
Dec 21, 2008 at 9:55 AM
Hi:
Chances are the cable need lubericated. You can remove it from the speedometer and spray some WD40 or = into the cable. Let me know if that helps. Also, make sure the cable isn't broken.
Mar 12, 2009 at 5:57 PM
