1984 Dodge Ramcharger missing
1984 DODGE RAMCHARGER
159,000 MILES • V8 • 4WD • AUTOMATIC
CGROSS
runs good cold misses when hot.
Aug 8, 2009 at 8:17 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Aug 8, 2009 at 8:21 PM
