Without Lift or Drop
DODGE RAM
KUHREK
  • 5 POSTS
I got a 1996 Dodge Ram 1500 Duel Cab 2x4 Pickup and I want to replace the factory size tires(225/75R16) to it. Can I put on 305/70R16 tires on it without a lift on it. I like those wide tires so which wide tires would fit without a lift or a drop on the truck?
Feb 23, 2007 at 9:01 PM
CHEVY22
  • 1,375 POSTS
i think that tire might be too big , but check this out , open your drivers door and check the vin sticker , it should have an optional tire size on it
Feb 23, 2007 at 9:09 PM
KUHREK
  • 5 POSTS
Thank you for the feedback but the 225/70R16 tire size is the only option on the vin sticker. Is there any other wide tires to fit the truck without a lift or a drop?
Thanks again
Feb 24, 2007 at 2:50 AM
CHEVY22
  • 1,375 POSTS
do you wanna keep the same height or tallness of the tire or go shorter and wider
Feb 24, 2007 at 7:10 AM
KUHREK
  • 5 POSTS
go wider and shorter
Feb 25, 2007 at 12:38 AM
CHEVY22
  • 1,375 POSTS
235/55/16 will drop it down and be much wider if i remember right they are about 8 inches wide on the tread , check on tirerack.com pull one up and check out the specs aginst the tire your running , oh and they atre avail in h rated , is you wat to go even wider you could do the 245/50/16
tired jim lol
Feb 25, 2007 at 12:56 AM
KUHREK
  • 5 POSTS
Hey thanks man, you helped out a lot.
Feb 25, 2007 at 2:26 AM
KUHREK
  • 5 POSTS
I made a mistake, the tires I got on the truck right now is 255/75R16 not 225/75R16. I'm sorry about that. So is possible to put on 305/50R16 on it than? Thanks again for your time.
Feb 25, 2007 at 2:31 AM
CHEVY22
  • 1,375 POSTS
305 might be pushing it , check that wesite i gave you , it is easy to use and very informative
take care jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 9:39 AM
