Vaccum leak on my 2001 Dodge Ram 1500 5.2L
2001 DODGE RAM
STANDROEGE
I have a 2001 Dodge Ram 1500 5.2L 2WD and I have a small vaccum leak. The code is P0442. I checked all the vaccum lines and couldn't see any leaks or cracks in the lines. Where should I look and how to pin point where the leak is coming from? Where is the most common leaks places?
Apr 20, 2007 at 12:56 AM
BACKYARDMECHANIC
  • 337 POSTS
The code PO442 means there is a small leak in the the cars evaporative emmission system. This system contains the fumes that the gasoline gives off instead of letting them into the air and recirculates them back into the intake manifold.The most common cause for this is a loose gas cap. If the cap is not closed tighly then you can cause the system to detect a leak. This will alert the driver with the annoying check engine light coming on. Check the cap and make sure it's tight and then clear the code. If it comes back then do a thorough inspestion of the EVAP system. Make sure to check all hose to and from the fuel tank that go to the manifold and canister.
Apr 20, 2007 at 8:28 AM
