01 DODGE RAM 1500 5.9 4X4
I AM HAVING A LOW OIL PRESSURE PROBLEM WITH MY TRUCK,FIRST OFF I AM AN ASE TECH SO I KNOW WHAT I AM DOING,SO ANYWAYS IT HAS LOW OIL PRESSURE AT IDLE AFTER ENGINE IS WARM,SO I WENT TO CHANGE THE OIL PUMP,IT ALLREADY HAD AN AFTERMARKET HIGH VOLUME OIL PUMP IN IT,THE SAME ONE THAT I BOUGHT,BUT I PUT THE NEW ONE IN ANYWAYS,STILL LOW OIL PRESSURE,SO I CHANGE THE SENDING UNIT,WITCH WAS LOOKED NEW,SAME LOW OIL PRESSUERE PROBLEM,AND ALSO I HAVE WHAT SOUNDS LIKE A SLIGHT LIFTER NOISE ABOVE 3K RPM,LIKE THE LIFTERS ARENT PUMPING ALL THE WAY UP,SO I PULL OFF THE VALVE COVERS AND CHECK ALL THE PUSH RODS,ALL ARE CLEAN AND I PERFECT SHAPE,THEN FINNALY THE VALVE CLATTER HAS GOTTEN A LITTLE WORSE AND NOW I HAVE A CYLINDER 1 MISFIRE CODE,SO NOW IM ALMOST SURE IT IS THE LIFTERS NOT PUMPING UP,BUT WHAT I DONT UNDERSTAND IS WHY IS THERE LOW OIL PRESSURE AT IDLE BUT WHEN ABOVE 1K RPM IT HAS 100PSI WITH THE HIGH VOLUME PUMP,AND NO ITS NOT BEARING CLEARNCE ALL BEARINGS ARE IN PERFECT SHAPE AND ARE NEW,I DONT UNDERSTAND WHAT TO DO HERE I WAS GOING TO CHANGE ALL THE LIFTERS BUT I DONT KNOW IF THAT WILL SOLVE MY LOW OIL PRESSURE PROBLEM OR THE VALVE CLATTER,AND NO ITS NOT SPARK KNOCK,ANY HELP PLEASE????????? THANKS -DANIEL
Nov 16, 2006 at 1:36 AM
