GETTING VEHICLE SPEED SENSOR MALFUNCTION
DODGE RAM
PKC28
I HAVE A 99 DODGE RAM 1500 4X4 AND IT STARTED NOT SHIFTING CORRECTLY AND CHECK ENGINE LIGHT CAME ON AND CHECKED THE CODES AND IT WAS THE VEHICLE SPEED SENSOR MALFUNCTION, OUTPUT SPEED MALFUNCTION, AND CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD LEFT SIDE. IS MY TP SENSOR GONE BAD?
May 17, 2007 at 5:49 PM
2CARPRO JACK
  • 11,533 POSTS
Not likely, sounds like you need a new ccat converter on the left side, or new head pipe as the case maybe. The VSS (vehicle speed sensor) might be going out on you.If the PCM cant see speed it wont know when to shift the trans
May 17, 2007 at 5:54 PM
