I have a 2004 Dodge Ram 2500 Diesel Truck. I installed a new K&N air filter system on it the other day. Following instructions I removed the Negative battery cable from both batteries. Everything went well and after I hooked up the battery cables again, tried it out and everything worked fine. However, my CD changer which is the stock 6 cd changer that came with the truck did not work. It had CD's in it when turned it off before i started to work on the air filter. The radio works but the only selection I get when i Press the Mode button is either AM or FM. The CD player makes noise like it is trying to eject the disk but nothing happens. Is this a common thing to happen when you disconnect your battery and how do i fix it ????????
Mar 22, 2006 at 2:08 PM
