2008 Dodge Ram LOW TPMS BUT CORRECT PSI
2008 DODGE RAM
CLASSICMALIBU
Engine Performance problem
2008 Dodge Ram V8 Two Wheel Drive Automatic 53000. miles
THIS JUST HAPPEN, LOST ENGINE PEFORMANCE
EVER SINCE LOW TIRE SENSOR CAME ON. LIKE SOMETHING IS HOLDING BRAKE'S. INDECATER STAYS FOR 75 SECONDS LIKE MANUAL SAYS AND THEN STAYS ON SOLID. IS THE TIRE'S SENSOR'S OR TREGGER MODULES.
Jun 10, 2010 at 9:22 PM
BMRFIXIT
  • 19,053 POSTS
Would a jump get it started ?
if so do a battery draw test and also drain test
check charging system and alternator diode function
smart battery tester should pick up any faults
old way of checking battery will not show the fault
If have a full size spare check the pressure in it too
Jun 10, 2010 at 9:41 PM
