Shakes or Wobbles problem
2006 Dodge Ram 6 cyl Four Wheel Drive Automatic
2006 4by4,diesel,4door,long wheel base. Vibration between 60-70 miles an hour under light exceleration, vibration goes away when you come off throttle very slightly. Seems to have started after #4 injector replace, not sure totally. Have pulled drive line to check u-joints and rotated and balanced tires. check motor mounts and tranmission mounts. When towing it doesn't seem to make any difference, vibration still there. Seems to get better and then will get bad again.
Dec 12, 2009 at 2:58 PM
