when I press the brakes on the drivers side I hear a thumping sound?
2006 DODGE RAM
40,000 MILES • V8 • 4WD • AUTOMATIC
JEFF DARCY
I recently changed the brake pads on the front of my vehicle. Now when I press the brakes on the drivers side I hear a thumping sound. I used a clamp to push the calibers in and did not run off the fluid. Could this have damaged the anti-lock system? If so is this going to hurt hurt to drive in the near future until I can get it checked by a mechanic? Is there anything I can do to fix the problem?
Dec 13, 2007 at 5:27 PM
2CARPRO JACK
  • 11,533 POSTS
Did you take the wheels back off and make sure everything was tight and good? When it thumps, does it do it until you let up off the pedal? Im not going to tell you it is ok to drive, because I dont know if it is,or whether or not anything will be damaged by driving it. If you look and all is good, no rubbing or loose bolts or wheels, then I would drive it to the shop ASAP, brakes are nothing to mess with
Dec 14, 2007 at 7:41 AM
Thumping sounds can be you got grease on part of the brake rotor, or the rotor is not true due to rust on the bearing hub before you installed it, please go over this guide which can help you:
https://www.2carpros.com/articles/how-to-replace-brake-rotors-correctly
Also, I would check the caliper mounting bolts to make sure they are tight. Check the diagrams below so you can see what I am talking about. Check out the images (below). Please let us know what happens.
Sep 28, 2024 at 6:23 PM
