2005 Dodge Ram wipers
2005 DODGE RAM
PITTBOSS
Electrical problem
2005 Dodge Ram V8 Four Wheel Drive Automatic 165 km miles
when the engine is running the wiper delay do what they want. they go one once then they won't work . only the delay. the low and high work fine. with the engine off and the key in the on position they work pefect in the delay and low and high.whats the cause of this problem? thanks
Oct 29, 2010 at 7:52 PM
SERVICE WRITER
  • 9,123 POSTS
Computer needs to see park sense signal sent by the wiper motor. May be a bad motor internally.
Also I have read of ground issues. One is the ground connection next to the drivers side hood hinge. Also a ground issue at BCM pin#6 and pin#8.
Oct 30, 2010 at 7:12 AM
PITTBOSS
what and where is the bcm?
Oct 30, 2010 at 11:12 AM
SERVICE WRITER
  • 9,123 POSTS
BCM- Body Control Module
In essence it is a computer that is like the pcm, but contols non- engine performance things...like wipers, lighting, locks etc.
Mitchell does not provide a location. Alldata may. but I do not have access until Monday.
Oct 30, 2010 at 7:07 PM
