2005 Dodge Ram VIBRATION FELT IN GAS PEDAL AT LOW SPEEDS
2005 DODGE RAM
75,000 MILES • V8 • 2WD • AUTOMATIC
CLAYTON1
At low speeds I hear a humming sound from the driver side front and can feel it vibrating in my gas pedal and steering wheel. When I turn right it is bad and when I turn left I can't hardly feel it. Brakes are new so I suspect a wheel bearing. What do you think?
Aug 5, 2010 at 8:03 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the left (driver side) front wheel bearing is bad. When you turn right you load the left side of the truck more, and left you take load off the drivers side.Lift and support the front and see if there is any play or looseness in the left front wheel.The hub/bearing assembly should just be a bolt in part that is easily replaced
Aug 5, 2010 at 8:54 PM
