2005 Dodge Ram OBD CODE 0406
2005 DODGE RAM
155,000 MILES • V8 • 4WD • AUTOMATIC
JETSKIINDUDE
Where is the EGR and can it be repaired or does it have to be replaced?
Feb 13, 2008 at 12:04 AM
MERLIN2021
  • 17,250 POSTS
It's not a code to replace the EGR, P0406=EGR position sensor circuit high voltage...you need to test the wires in the 5 volt ref circuit between the sensor and the PCM. Do you have a scanner that can read sensor values? If yes read the EGR position sensor voltage, is it above 4.5volt or below?
Feb 13, 2008 at 8:26 AM
JETSKIINDUDE
I'm not sure. I borrowed a scanner from Autozone. Can it be read with a regular OBD scanner or do I have to read it off the EGR wires themselves? And thank you for your help.
PATS FAN MYSELF!!!!
Feb 14, 2008 at 10:01 PM
MERLIN2021
  • 17,250 POSTS
Yea those Pats...All year...then....BAM!
Some scanners can give the voltage but not many...Will most likly need to test the circuit itself, with a DVOM.
Feb 15, 2008 at 7:45 AM
MERLIN2021
  • 17,250 POSTS
I will look further...
Feb 15, 2008 at 8:07 AM
