2005 Dodge Ram Idler wheel
2005 DODGE RAM
30,000 MILES • V8 • 4WD • AUTOMATIC
JDODGE 2005
What are the signs that my idler wheel could be going. Currently when my vehicle is under load I have a ticking sound that gets louder as I accelerate. When my vehicle is in neutral and I step on the gas there is no noise what so ever.
I'm concerned but would prefer to do the change my self. Any ideas?
Feb 8, 2010 at 9:05 PM
CARADIODOC
  • 34,308 POSTS
The bearings in idler pulleys usually make a buzzing noise. A tear on the serpentine belt could make a ticking noise, but you already noticed the most important clue; it only happens under acceleration. Idler pulleys and serpentine belts don't know or care how much load the engine is under. Any noise they would cause would still occur while you were poking around under the hood.
What you did a dandy job of describing sounds exactly like an exhaust leak. You might be able to make the noise occur by holding the brake applied, standing still with the truck in drive, then press the gas pedal to put the engine under load. Your mechanic would do the same thing with a helper inside the truck while he inspects the exhaust system.
Typically this type of leak occurs between the exhaust manifold and engine or between the manifold and exhaust pipe connection. Although it's possible, rust holes in the muffler or pipes don't usually cause a ticking noise.
caradiodoc
Feb 9, 2010 at 10:45 PM
