my fan belt pully is loose. I can shake it back and forth. Theres not a bolt that i can see to tighten it to the block. how do i tighten it
Feb 20, 2010 at 12:22 PM
DOCFIXIT
CERTIFIED EXPERT
If 5.7L which one in diagram?
Feb 20, 2010 at 12:47 PM
COLT
MEMBER
probably need a new water pump, if that pulley is loose then im guessing the bearing went out on it and if its the fan belt that should be running the water pump also
