2004 Dodge Ram Windows
2004 DODGE RAM
83,000 MILES • V8 • 2WD • AUTOMATIC
NICKMAGNUM04
I think my childlock is permanently on. I can control all the windows in the truck, but the passenger windows cannot be controlled by their respective controls. EVERY ONCE in a while all the controls in the truck will work. 95% of the time, the main controls are the only ones that do. Don't know much about wiring. Is this something I can fix myself or do I have to take it in? Any info would be helpful.
Feb 8, 2009 at 10:12 PM
Hi:
You need to check if the passanger side switch is getting power (when it isn't working) If there is power to it but none coming out, it needs replcaed. You would need to remove the door panel (a few screws, clips...) to get to the switch to check and replace. But after that, a couple screws, and an electrical plug is all that needs done.
Feb 13, 2009 at 5:50 PM
