This repair is the same differential as a Chevy pretty much, here is a video that will show you how
https://youtu.be/zarxKsspr3s
AXLE BEARINGS
REMOVAL
Place transmission in neutral.
Raise and support the vehicle.
Remove wheel and tire assembly.
Remove brake caliper, adapter and rotor.
Remove axle shaft.
NOTE:The seal and bearing can be removed at the same time with the bearing removal tool.
Remove axle shaft seal from axle tube with a small pry bar.
Remove axle shaft bearing with Bearing Remover 6310 and Foot 6310-9
Aug 2, 2019 at 4:10 PM
(Merged)
