2004 Dodge Ram Changing driver side mirror
2004 DODGE RAM
DENOUSH
Interior problem
2004 Dodge Ram 6 cyl
I am trying to take the interior panel off so I can change the mirror. After taking out the four screws I'm not sure how to get the panel off. It is still tight and not willing to budge. I don't want to break anything. Can you please advise on the next steps?
Jan 13, 2009 at 6:58 PM
Hi:
Carefully check behind the panel. I believe you will see either plastic or steel clips attached to the panel and pushed into holes in the door. To remove them, I always use a screwdriver to carefully pry them out. Note: It is common for them to break.
Jan 15, 2009 at 3:46 PM
