Hi, Was The Caster, And Camber In Spec. When Alignment Was Done? Does It Pull When applying The Brakes? If It Does, It May need A brake caliper , And brake hose. Also Try Swapping The front Tires Side To Side .If After Doing that ,And Pull Is To the Left Instead Of the right,Then It's A Radial Tire Pull. I've Seen New Tires cause this. If All This Is Good Then You may Have A Ball Joint Causing A binding Condition.By Removing The Nut And cotter pin From The Out Tie rod end . And turning The spindle To See That it's Not Tight Or binding.
Hope This helps You,
Good luck
Edward S.
Jul 20, 2010 at 5:15 AM
