2.Remove or disconnect the following:
Front wheel
Brake caliper
Grease cap
Cotter pin
Adjusting nut
Washer
Outer bearing
Brake rotor and hub assembly
Grease seal
Inner bearing
To install:
1.Install or connect the following:
Inner bearing
Grease seal
Outer bearing
Washer
Adjusting nut. Adjust the bearings.
Cotter pin
Grease cap
Brake caliper
Front wheel
Mar 31, 2010 at 7:58 PM
