2002 Dodge Ram pinion seal leak
2002 DODGE RAM
93,000 MILES • V8 • 2WD • AUTOMATIC
EZRDR55
How do I change the pinion seal
Aug 17, 2010 at 7:30 AM
Mark the companion flange so you can line it up when you put it back together. Next, remove the flange. Remove the nut and washer from the pinion, using a puller:
https://www.2carpros.com/forum/automotive_pictures/249084_5_49.jpg
Remove the seal with a slide hammar and replace it. Make sure to put a thin coating of gear oil on the lip of the seal. Also, make sure to replace the nut and washer. NOTE: The convex side of the washer must face out. Let me know if this helps. Joe
Aug 18, 2010 at 12:16 AM
