2002 Dodge Ram Dash lights off on, headlights off on no key
2002 DODGE RAM
116,000 MILES • V8 • 2WD • AUTOMATIC
RICH A
Replaced ignition sw, small harness. New battery, I took headlight switch out of loop still has problem.
When I pull fuse to dash/radio I can simulate problem at times.
head lights turn on in driveway then turn off. NO key parked.
When head lights turn on, dash light in vehicle go off.
While driving dashlights go off going down hill at times.
If I put in reverse at times dash lights come on.
If everything works, when stopping during day, when I open the door chime rings that key is in ignition , but is not, then when key is put in no dash lights.
Repair shop says don't have a clue.
I need map of where things are under hood.
I think this is a swinging short somewhere.
Thanks
May 29, 2010 at 4:00 AM
DALE NEWELL
I had a 1996 Dakota that had the exact same problem, I cleaned all the grounds and electrical connections and that did the trick for me. It was an ongoing problem and needed attention every spring, I think it was partially due to poor quality wire used and I did replace a few ground straps over the years but it is still running and has 180,000 miles. Hope this helps and good luck. Dale
[quote:ce862f95db="Rich A"]Electrical problem
2002 Dodge Ram V8 Two Wheel Drive Automatic 116000 miles
Thanks[/quote:ce862f95db]
May 30, 2010 at 9:21 AM
